TRAILER REBUILD
sarfarm
Thought some may like to see my latest trailer build.
The chassis was built some time ago for use as a flatbed but recently I upgraded to a larger unit and decided to build a camper,the body uses parts from an aluminium box van reduced in size to my needs.
The entire unit is of alloy pop riveted and bolted as needed,some 600 pop rivets used.
To date the box is ready for cleaning up and then the interior will be done using styrofoam insulation and plywood.Photo0007.jpgPhoto0006.jpgPhoto0009.jpg
PS.The unit in the front is a home built 12 volt generator producing up to 70amps.
nahuebsch
