Hello Everyone,
Still getting my 99 set up for this up coming summer for all points south . So since I bought this rig I have done a top end rebuild . Replaced the tension pulley recently.. Crank shaft sensor... Since owing this rig it has always kinda hesitated from 1-2 when driving normal speed down the street in the neighborhood. Then this morning when acelerating out of a turn it jerked pretty bad . Pulled around a corner got out to check things out . Everything seemed fine under the hood. I was close to home thank God...
So the fluid is ok and not super dirty . So does anyone have an idea what this issue might be ?
Should I try a tranny flush and new fluid to start .
Has some kind of a sensor gone bad ?
Looking for a good shop in the Portland , OR area .. I will bite the bullet with the dealer if I have to ..
Thanks ,
Marshall mk-75
Thanks ,
Marshall mk-75
