nick disjunkt
Hi all,
I'm still driving around the south east of the US and I was hoping someone could recommend a place to get the brakes on my Mercedes 1823 looked at in Texas, preferably near Austin or San Antonio.
In the south of Florida I had a calliper fail to release on one side of the rear axle after being parked, and when I stopped to check what was slowing the truck down, the disc was glowing cherry red. After letting it cool down, it has worked fine since, and the disc and pads both have plenty of material left on them, but the disc probably need the surface remachined, and the parking brake is taking longer on that side to release. I suspect it's a problem with the parking brake side of the air chamber (the chamber on the other side was recently replaced as the diaphragm was leaking), as a problem with the parking brake valve would cause both sides to stick, and a problem with the caliper would happen with the ervice brake as well as the parking brake.
I've since driven around 1500 miles and have had no problems with the brakes but after it got to 20 one night, the parking brake needed more encouragement than it should have to release so I suspect the problem may reappear again at some point.
A freightliner garage that I visited in Tampa told me that air powered disc brakes are fairly new in America and did not want to waste my time trying to learn on the job.
Have any other manufacturers been using them for longer? or can anyone recommend me a general truck repair place that would be competent looking at the brake for me? The calliper is much like a car's, but larger, and the air chamber is pretty much the same as on drum brakes, so the technology is not too fancy.
I suspect we'll come across more European trucks in Mexico so if necessary I guess I can look for a Man garage on the other side of the border.
Thanks for any help,
Nick
Nick
