Truck camper plumbing help please
ripperj
Could use a link to rv plumbing or just a quick flow path. '85 Alaskan. Have bought 20gal water tank/ shurflo pump, 6 gallon propane hot water. I have installed residential furnace and hot water heater. I assume I run a filter from bottom of tank to the pump and then tee to hot water heater and cold taps. I then let the pump pressure switch turn the pump on off? I assume you turn off the pump at night and kill master power when away. Sobsytrm is always pressurized when the switch is on?
thanks
Sent from my Z10 using Tapatalk 2
dhuss
