Truck sitting uneven after lift... How to fix?
DarkHelmet
Now 10 months after installing my OME Lift on my 05 Tacoma Quad Cab, it seems to be about 1/2" - 3/4" low on the driver's side front. Actually, the truck seemed a bit uneven before the lift.
Any thoughts on how to even things up? I see TRDParts4U has OME 5mm Trim Spacers. Is that for leveling?
Advice is greatly appreciated.
- DH
scarysharkface
I had a '95 Dodge Dakota that sat that way. Upon close inspection, the body mount points were off by that much. So I guess I'd would be inclined to check whether the frame is level or not first, and go from there..
John
Overland Hadley
on a journey
I think a lot of Tacoma's have a driver side lean, as the battery and gas tank are both on that side.
Is your 3/4 lean measured from the front or the rear?
Mine leans to the driver side, I just try and load the heavy stuff on starboard when packing for a trip.
craig333
My old dodge leaned. Even after I put new springs on it. My Jeep leans. I've learned to live with it. As long as they track straight who really cares. Its not worth the effort it would take to fix it.
YaRiteZ71
