Tucson AZ ALU Cab Tilting Fridge Slide $275
DDT
ALU Cab Tilting Fridge Slide TFS50 Tilting Fridge Slide 50 qt
Purchased from ok4wd for $379. Installed and immediately removed-Like New- Will sale for $275 cash.
See at https://www.alu-cab.com/product/tilting-fridge-slide/
or
https://ok4wd.com/brands/alucab/alu-cab-tilting-fridge-slide-large-fridges
now $479 on website
The tilting fridge slide from Alu-Cab will fit most large fridges.
The Alu-Cab tilting fridge slide is a convenient fridge slide that allows you to safely mount your fridge in confined areas. The drop down fridge slide allows you to pull your fridge out of the vehicle and tilt it down for convenience.
This tilting fridge slide fits the following fridge freezers:
  • National Luna 55L/60L
  • Waeco CFX 50
  • Waeco CFX 65
  • Snowmaster BD/C-60
  • Engel 60LT
  • Engel 75/80LT
  • ARB 63QT (Non-Element)
  • ARB 80QT
  • If your fridge freezer is not listed, this fridge slide will fit a fridge freezer up to a 800x500 ( 31.5"x19.68")
Alu-Cab’s new Tilting Fridge Slide now operates as a straight pull out slide, and it has the option to tilt. This means you have the advantage of a fridge slide that runs on stainless steel runners with sealed stainless-steel bearings. This product offers maximum strength with the ability to carry greater loads, with greater resistance to dust and the harsh off-road conditions.
With double locking pins, it is secured firmly in place when locked in position – with no risk of the fridge slide breaking free when the road gets rough.
The fridge slide allows easier access when the fridge is positioned at height. It also helps to clear the canopy or back doors when there isn’t space to open the lid. Built from both Stainless Steel and Aluminium, this tilting fridge slide offers good strength without adding excessive weight.
dhuss
