Tufport T60 - Camper Fiberglass Shell Cabover - Fully Enclosed - Oregon - $3900
montypower
Adventure Time!
TufPort - T60 SUPER CAPACITY
I purchased this with the plan to build a camper. It is rather ideal with the light weight, water/dust tight, low overall height profile. It is a fully enclosed unit that can easily be lifted out of the rig (has a floor). Heavy duty commercial grade type construction. It is not noticable on the Tundra. Fuel mileage went down only 1mpg mixed driving (16mpg without / 15mpg with it). On the road it is still 17mpg with the shell. This is extremely versatile unit. Secure locking door (with interior handle). Walls are reinforced, designed to anchor shelving. Automotive grade double door seals. It is unlike any canopy or fiberglass cover built, quality is top notch.
Ideal for: Tradesman / Electrician/ Courier / Equipment Technician / Plumbers / Camper Conversion
"With an interior height of 60", our T60 Super Capacity is the perfect size if you're looking to take your workshop on the road. With over 262 cubic feet of storage space it's ideal for stacking and racking all of your tools and equipment."
Ext. Height: 5' 5"Int.
Ext Length: 6' 6"
Interior Height: 5' 2"
Interior Max length: 81" - Minimum Length 80"
Interior Max Width: 74" - Minimum Width 49"
Cab Over: 30" Deep
60/40 Door Width: 49"
60/40 Door Height: 53"
Storage Space: 262 cu. ft
Weight: 500lbs(228kg)
http://www.tufport.com/utility-work
http://www.tufport.com/tech-specs
This T60 has the following upgrades:
60/40 Double Rear Door (50" opening)
Alumnium Roof Vent
12V Power Point
Cab Sliding Window
110V Interior Recepticle
Exterior Black Paint
New Cost $10,875.
It will fit any full size truck (Ford, Chevy, Toyota, Dodge). Designed for 6.5ft bed length.
Will sell brand new lifts to remove the T60. Additional $400.
$3,900 Cash - I'll include the canopy jacks FREE if you bring full amount in cash by September 23rd. Located in West Linn, OR. Can transport to Bend, OR.
503.888.6967
