montypower
Adventure Time!
TufPort - T60 SUPER CAPACITY
Ideal for: Tradesman / Electrician/ Courier / Equipment Technician / Plumbers / Camper Conversion
"With an interior height of 60", our T60 Super Capacity is the perfect size if you're looking to take your workshop on the road. With over 262 cubic feet of storage space it's ideal for stacking and racking all of your tools and equipment."
I purchased this with the plan to build a camper. It is rather ideal with the light weight, water/dust tight, low overall height profile. It is a fully enclosed unit that can easily be lifted out of the rig. It is not noticable on the Tundra. Fuel mileage went down only 1mpg mixed driving (16mpg without / 15mpg with it). On the road it is still 17mpg with the shell. I decided to build a 4x4 Van into a camper. This is extremely versitile unit. Secure locking door (with interior handle).
Commercial grade construction. Automotive type door seals (dust/water tight). Locking door with key. Interior latch. Easily cut in additional windows. Extremely simple to modify. The entire unit lifts out (completely enclosed). Perfect for multi-purpose truck use.
Ext. Height: 5' 5"Int.
Ext Length: 6' 6"
Interior Height: 5' 2"
Interior Max length: 81" - Minimum Length 80"
Interior Max Width: 74" - Minimum Width 49"
Cab Over: 30" Deep
60/40 Door Width: 49"
60/40 Door Height: 53"
Storage Space: 262 cu. ft
Weight: 500lbs(228kg)
http://www.tufport.com/utility-work
http://www.tufport.com/tech-specs
This T60 has the following upgrades:
60/40 Double Rear Door (50" opening)
Alumnium Roof Vent
12V Power Point
Cab Sliding Window
110V Interior Recepticle
Exterior Black Paint
New Cost $10,875.
It will fit any full size truck (Ford, Chevy, Toyota, Dodge). Designed for 6.5ft bed length.
Will sell new side lifts to remove/install the T60. Additional $400.
$4,900 Cash
Located in Portland, OR. May be coming down to Bend, OR shortly.
Ext Length: 6' 6"
Cab Over: 30" Deep
Alumnium Roof Vent
12V Power Point
Cab Sliding Window
New Cost $10,875.
$4,900 Cash
