Metcalf
Well, it looks the the common ( wealthy ) man can now have the CRD liberty swapped into there TJ/LJ jeep!
http://www.burnsvilleoffroad.com/Articles/LibertyDiesel.aspx
http://www.burnsvilleoffroad.com/Images/Articles/LibertyDiesel/4WDP-100200-DSL-44-48.pdf
http://www.4wdandsportutility.com/features/jeep/1002_4wd_2006_jeep_wrangler_tj_diesel/index.html
Burnsville Offroad was finally able to pull off a full conversion where everything works. AEV was the first to do this, but they will not do another. Burnsville was able to pull it off by swapping the dash cluster and steering column from the Liberty. They also had to swap in a set of JK axles in order to get the ABS speed signal that the computers need ( for cruise control if I remember correctly ). Burnsville also pulled off a 6-speed manual conversion with the Rubicon 4:1 transfer case for you gear grinders.
Overall though this is pretty promising. Being able to use the JK axles for the ABS speed signal solves the last part of the puzzle. This swap could be done now by a talented individual in there garage.
As a note.
-Full backspacing JK wheels would pull the width down to the same as 17" AEV Pinters on TJ axles.
-AEV was able to pull off this conversion by using a small interface computer between the liberty computers and TJ dash cluster.
-Hotwire also did one conversion but was missing the ABS signal so the Cruise control would not work and they had some automatic transmission control glitches.
-Green Diesel Engineering is also doing some very interesting work on reprogramming the engine control computer.
http://www.greendieselengineering.com/
The last piece of the puzzle is really the reprogramming of the stock transmission computer. I hope someone cracks it soon.
Good news all in all.....anyone now where to find a wreaked CRD libby?
As a note.
