Two Zone Ezy-Move: Product Review and Install
Dave Bennett
Adventurist
I acquired this cool Ezy-Move for my Engel MT-45, courtesy of Forum and Expedition Trophy Sponsors Sierra Expeditions.
The Ezy-Move is made by Two Zone, Australia.
http://www.sierraexpeditions.com/index.htm
Total install time was 5 minutes
Tools required: 1 phillips screwdriver.
Difficulty of install on a scale of 1 to 10 (10 being way too hard), this was only a 1...
Step 1: Expose the bottom rear edge of the Engel.
Step 2: Remove corner protectors. They are not needed once the Ezy-Move is installed so I put them away in my toolbox. The screws are used to attach the Ezy-Move later on.
Step 3: Slip the Ezy-Move in place. It is a perfect fit.
Step 4: Attach the Ezy-Move using the screws removed during Step 2. Do not overtighten!
Step 5: Admire your work!
The Ezy-Move turns your Engel into a rollable, mobile unit.
Due to it's elongated roller design, the Ezy-Move handles most any surface with ease.
The Ezy-Move slides in easily now and interfaces perfectly with my Engel Transit Lock.
My overall impression of the Ezy-Move is very positive.
Now, when loaded down with goodies, it can be easily rolled out to the truck for loading, and rolled back in at journey's end. Adding the Ezy-Move to an Engel transforms it from a two-handle carry to a rolling fridge.
The rollers are a Delrin type material and should last for years, this is a heavy duty accessory made for Expedition use.
And, considering the fact that a fully loaded Engel MT-45 can easily exceed 100 lbs when loaded up with goodies, this accessory is a real back saver and a must have!!!
That seems pretty cool and will certainly make moving them around a little easier. I am interested in how it holds up when it gets full of dust, dirt and a little orange juice so keep us posted.
Is it possible to still get the cover on?
Rob
Update
Well, after almost two years of ownership the Ezy-Move is still going strong.
My only issue has been noise when underway... it will make a little bit if left alone.
I solve this by placing something near the roller so it does not vibrate.
This has been a nice accessory to have as my wife can now move the fridge when fully loaded if/when she wants to.
Overall, a very good product!
Jlbeats
