u bolts welded to axle?
86bigyeti
I just got a new to me k5. After I got it home I noticed that the u bolts are welded to the axle. Never seen it done before my only guess is the p o did this to set the angle instead of shims for the 6 in lift. Any ways is this safe is it really bad no one I talk to has ever seen or herd of this before
wesfab1
Goin' Commando
That's a hack job, and I'd say not safe at all. Ubolts don't like heat, they get brittle and snap. Welding makes heat, you do the math.
86bigyeti
OK thanks. Now how do I fix this I'm a weder so I know a good weld whoever did was a fantastic welder they did a complete pass both sides both springs grinding them off makes me nervous is it new axle time?
v_man
pictures would be helpful ... a lot of people claim not to re-use U bolts ... I've loosened and re-torqued mine numerous times though .
86bigyeti
How thick is the axle? I know people weld to them all the time but will heat from the torch or grinder be an issue. I can get a 10 bolt axle for $100 or a Dana 60 for $400 but I don't like to spend if I can fix it
1v6pony
If it were me, i would start over, you do not know how good a welder he is, he might have overheated the metal witch will fatigue much easier than the weld itself.
and you have a torqueee, motor also, not worth the risk of being in the middle on nowhere and it braking. or even a hard street emergency braking situation.
better safe than sorry.
rayra
Depends how hard you're gonna use it. Sure the welding might have messed with the tempering of the U-bolts AND the axle housing, but so will burning or grinding them off. If you are going to put a lot of side load or torque on them rock crawling, then get a new axle housing and U-bolts. If you're just cruising about and hitting some dirt roads, don't worry about it at all. But you might consider carrying some spare u-bolts and the tools to make an emergency repair in the boonies.
gohuge
Axle tube is pretty thick material. I would grind them off and replace the ubolts.
It is unlikely that he cooked the tube enough to weaken it. Crazy booty fab though.
Guy must have never heard of a wedge.
crazybill
Wire brush the heated area and inspect for cracks. Otherwise I'd go with it unless you have a reason to change it.
You say you are a welder (as opposed to "I can weld") so you should know what to look for. Spring towers and perches, shock mounts etc are welded to the tubes all the time.
-Bill-
-Bill-
What bill said.
86bigyeti
Thanks guys I will grind the u bolt and welds off and use it. All kinds of booty fab on this thing. Its getting a new wire harness and complete axle rebuilds I plan on taking the wife and kid way out in the boonies and some light wheeling. Thanks again
