ultra portable power packs & boost capabilities
Anyone with some real-life experience with those ultra portable power packs that can also boost your vehicle?
I'm at a point where I'd like extra power in the Jeep - mainly so I can keep things charged over night (cameras/phones), as well as run some area LED lighting at camp. I'd like to jump start a drained battery if necessary.
Thought of goal zero (yeti), but no way to boost vehicle.
Canadian big box store has a booster/power pack on sale for $190 - 33Ah AGM battery like Goal Zero, but with booster clips. Weighs 28lbs.
Amazon has those "mini" Lion booster packs with 15-20Ah batteries for approx $100.
So... I'm wondering what I'm missing here - for the price of 2-4 of those mini booster packs (assuming you could run them in parallel), I've got more than double the aH of a Goal Zero Yeti (or equivalent), plus less weight and more portability.
Thoughts?
Antichrist
Why not just an auxiliary battery in your rig? Would probably take less space and would definitely be cheaper given the prices you're referencing.
I've been looking a dual battery setups - $300x2 for batteries and another $400 or more on the battery tray & isolator. I was keen on finding a lower cost alternative.
anickode
Why do you need 2x 300 dollar batteries? Even a single 100 dollar big-box store marine deep cycle will have 4x the amp-hour capacity of a SLA booster pack.Those little booster pack batteries also take a HUGE hit on their lifespan every time you actually use it to jump start. A lot of them won't start a car with a flat dead battery, but rather will only assist a weak battery. A 30 dollar continuous duty solenoid from the auto parts store makes a cheap, reliable, basic isolator.
My auxiliary battery setup only cost around 200 bucks all-in. It's not the fanciest, and I don't have multiple top-shelf AGM deep cycles, but it works, and it's a WHOLE lot more useful than a booster pack.
Heck, even just purchasing a sealed deep cycle and tossing it in a plastic battery box in the back wouldn't take up much more room than a booster pack, and would give you a whole lot more capacity. Just ********** it on a charger before you leave, just like you would with a booster pack. If you bought an oversized box with a divider, you could use the empty space to install a couple cigarette lighter plugs, a small inverter, and an automatic trickle charger to recharge and maintain it when you're home.
anickode
This one was posted by another member a few days ago. His includes a solar charge controller, which obviously isn't necessary if you aren't running solar. I'd be far happier with a setup like this than with (even a really expensive) booster pack.
attachment.php
attachment.php
Thanks... looks like I need to do a bit more research and come up with a solution. I'd like the best of both worlds (small size/portable), but with as much reserve capacity as possible. I'll figure out where i need to compromise!
Antichrist
A lower cost alternative would be not looking at the "perfect" setup, but something that will get the job done that you want done.
http://www.amazon.com/HERSEE-TERMINAL-CONTINUOUS-SOLENOID-24213BX/dp/B00FGJIJR6
http://www.amazon.com/JEGS-Performa...8&qid=1430965736&sr=1-9&keywords=battery+tray
AndrewP
To do it right IS going to cost money, but maybe not this much. Get 2 x $100 batteries at costco, a standard starting battery and a marine battery for your house battery. Then get an $85 Blue Sea smart relay and $50 worth of 2 ga wire. The battery tray though, costs what it costs. Having a second real battery is huge. It's almost required for any remote camping and fridge use. It gives you a lot more flexibility than a starter pack.
anickode
I'm wondering what the deal is with buying two batteries? Would the vehicle not already have a starting battery in it?
Or is it an issue with the aux battery tray replacing the factory one, and both batteries must be sized accordingly? I guess I'm used to trucks, where a second battery is usually mounted on a second tray under the Hood or elsewhere on the vehicle.
It's a sizing issue.. and I've been a bit hard on the starting battery so figure it would be worthwhile replacing it at the same time... not to mention I still desire portability. Although I love what I'm doing with my "expedition" jeep, I often think I'd be better suited to get a cargo van and build it into an expedition rig (and would then want to move over some of my add-ons).
