Now that we have our camper on our truck it is time to think about under the truck storage. I made measurements and have found that in most areas we have 28 to 29 inches from the edge of the flatbed to the frame member of the 2006 Isuzu NRR on both sides of the truck.
The muffler and some other bits are 20 inches below the underside of the flatbed, so this has me thinking 18 inches for height of the under truck boxes would not hinder our rutted road clearance ability by too much. This isn't supposed to be a rock crawler anyway.
20# propane tanks are exactly 18 inches tall and as such will not fit in a standard 18 inch high box. We may end up building a cage to hold 4 tanks (maybe welded steel frame with a expanded metal sides and embossed aluminum front.
I have found a company that sells 36 inch, 48 inch, 60 inch and 96 inch long aluminum truck boxes that are 24 inches deep and 18 inches high. Most companies had 18 x 18 but if you search for semi trailer boxes you can find the 24 inch depths. This company is protoolboxes and a example of a 0.100 embossed aluminum box that is 18h x 24d x 48l for $605 US is here :
http://www.protoolboxes.com/ATRG5-18-Height-x-24-Depth-x-48-Width-Aluminum-Semi-Truck-Trailer-Box-Toolbox-Super-Heavy-Duty-Drop-Open-Door-Smooth-Finish-Box-with-Tread-Plate-Door-and-Double-T-Handle-Locking-System-P2517.aspx
Opinions? Would you rather have aluminum over steel?
Here is a view of our truck with our camper on it. We would be putting about $3,000 worth of boxes based on that website's prices.
