Unicorn Sprinter 144 High Roof 4x4 Passenger van converted to dry camper ($85,000)
fergoose
Hi All,
It's time to sell our beloved Sprinter. The growing family just needs a bit more space.
Here's what she is:
- 2017 high roof passenger 4x4
- 32,000 miles
- In great condition. We've had no mechanical issues with the van and it's had all it's factory services done at Mercedes.
- There are two small door dings on the passenger side rear panel, the drivers side door has a 1 inch scratch at the top, hood has normal small paint chips (pinhole size) from rock/road debris
- Pretty loaded from the factory with drivers assist pkg (blind spot sensors, front/rear sensors, lane assist, crash avoidance), engine block heater w/ remote start, second deep cycle auxiliary battery to power lights, charging ports, etc), xenon adaptive headlights. Passenger van gets you rear A/C and heat plus speakers throughout. We also have 2 rows of the factory 3 seats benches. Can seat up to 8 with all the row in or 5 if in camping mode.
- The design was to give maximum flexibility so it could be used during the week as an around-town kid and stuff hauler and then easily convert to a weekend camper.
- Replaced factory head/stereo with Kenwood DDX9705S w/ dvd player, Sirius satelite radio and rear camera
- Custom conversion completed by Inspired Vans out of Teton Valley near Jackson Hole. Used many components from Adventure Wagon.
Conversion includes
  • Electrical – A complete wiring harness and accessories to power the van cabin. The fully assembled and loomed harness connects to the stock Sprinter battery and includes leads for two fans, six lights, four UBS ports, four 12v ports, and two accessories (heater, sink, etc.). Includes 4 LED lights. The eight included power ports are marine grade.
  • Insulation –Hushmat sound deadener, 3M wall and ceiling insulation pre-cut to match the Sprinter interior cavities, and double-sided tape for installation. All interior panels also have reflectix installed on the backside for added sound and heat insulation.
  • Ceiling Fan - One MaxxAir Deluxe ceiling, with mounting base, trim ring, weather seal, electrical connections and installation hardware.
  • Wall and Ceiling Bracers – Powder-coated, pre-assembled bracers used for L-track installation points and to support our bed and storage systems. Includes all hardware.
  • L-track – Aircraft-style L-track pre-cut and pre-drilled. Four (144WB) vertical wall tracks, four horizonal wall tracks and three ceiling tracks with mounting hardware. L-Track floor-mounted in rear for additional cargo tie down or bike mounts.
  • Wall and Ceiling Panels – Cut-to-fit 6mm marine-grade, plywood panels, upholstered and backed with Reflectix insulation. Bamboo ceiling panel.
  • Molded Trim – Custom-made, upholstered interior panels to complete areas above sliding door, behind driver’s head, rear door jamb, and driver’s side crew window. Custom fitted matching upholstered headliner over driver/passenger
  • MOAB Elevator Bed...Welcome to MOAB - the Mother Of All Beds. This patent-pending system will reinvent how you look at your sleep and cargo options inside your van. The MOAB platform provides one of the lightest and strongest van bed systems out there. The MOAB bed provides the flexibility of different height and width mounting options inside your van with three individual telescoping panels. For safety, these panels lock into place to keep them secured under load and movement. Queen size memory foam mattress included. The bed easily adjusts heights with four bolts. it can go from knee height all the way up to the ceiling. We mounted at a height that enables sleeping up top and also a bunk below for our daughter. The bed is rock solid and tied into extra internal bracers installed in the walls and ceiling.
  • Two large MULE storage bags: 175 Liters of storage (10,700 cu in). The equivalent of two large expedition backpack. Install and takedown in minutes. Collapses into a flat pack. Composite panel inserts add strength and shape to the bags. External pockets and webbing allow for quickly securing external gear. Two big 17” x 10” inch door openings along with a magnetic door flap. Made with rip-stop water resistant nylon fabric
  • ESPAR S2 D2L Van Heater with high altitude kit. This has a digital thermostat you set and enjoy a perfectly warm van all night long. It taps directly into the diesel tank and has a safety shutoff.
  • Aluminess Full bumper replacement with Hella fog lights, locking compartments, and space for winch (we didn't put a winch in)
  • Alpine Mechanisms swivels on the front two seats. Will include Cabbunk cot that turns the front seats into a sleeping area for kids.
  • Custom window coverings on all windows by Ripplewear. Includes bug screens for front 2 windows.
  • New Cooper SnowClaw LT tires. Less than 1k miles on them LT265/75r16
  • 2" hitch and running boards
