Unimog 1300L w/ camper in LA (no affiliation)
globalexcursion
http://losangeles.craigslist.org/lgb/rvs/2579781828.html
This Unimog 1300L has factory remanufactured OM352A turbo diesel engine that was installed in September of 2006, since then only 17,016 km have been put on the engine (a round trip from Colorado to Baja and then a trip to California). Mechanically the truck is in sound shape and could be quickly readied for its next adventure.
I spent hundreds of hours designing and fabricating this camper. The camper is constructed out of 2" steel tubing, using receiver hitch tubing for the two front corners and the two vertical members that make the columns between the exterior rear exterior doors. The camper is a popup that gives 6'1" interior head clearance when the linear actuators are extended. It is skinned with steel and then painted with Rhino-liner. There is 2" of high density polyurethane foam insulations in the wall and ceiling of the camper.
The camper has a forward table with center facing seats, which convert to a bed that will sleep two. Below this space there is a 80 gallons of water, an Isotemp hot water heater (mounted externally) (http://www.defender.com/product.jsp?path=-1|51|10172|319676&id=110202) a flowjet freshwater pump, a nature pure water filter, six AGM batteries to power the camper and a bit of storage space. There is 5' of counter space one cabinet three drawers a two burner electric stove and space for an Engel freezer. Opposite the counter the is a four door cabinet: one door houses the electrical system 3000 W Xantrex, BlueSky Solar boost module 24 V to 12 V converter and Breaker panel; three drawers; two storage areas. There is a bed in the back with shelves surround (a custom made memory foam matresss). Below the bed is outside access to a large storage area, where the boat, motor Honda 2kw generator and other gear is kept. On top of the camper are two 185 watt solar panels. There is a Espar hydronic heater that functions to warm the engine in extreme cold conditions as well as heat the camper.
16' Zodiac G470 with a OMC 35 hp ACT Pump Jet drive (http://actorlando.com/pump-jet-propulsion.htm). I have lots of spares including a complete lower drive unit, impeller and many engine parts [multiple carb and fuel pump kits and many many more]). The boat has an Alligator Skin covering from Alligator Marine (http://alligatormarine.40eleven.com). Included are two rigid and 4 collapsible gas tanks made by Nautica to give you amazing range for the boat.
Extras include a davit with electric winch for loading and unloading of the boat, motor and spare tires; 24 volt spool gun welder; spare starter; and miscellaneous spare parts for truck camper and boat.
Also included is an adapted (stretched tongue) U.S. military 1 ½ ton trailer M105A2. The box is made of aluminum and interior dimensions are 6'4" x 9'. This trailer has bows and a vinyl cover.
There are some cosmetic issues with the truck. The clear coat is peeling off of the hood and there are some scratches here and there. The power coated rims and bumpers show some spotting and the lug nuts have surface rust.
I built this camper in 2004 on a 1978 Mercedes Benz Unimog 1300L chassis so that I could take an extended vacation to drive to South America to explore off the beaten track locations by land and sea. One of the chief design considerations for the camper was the ability to carry a Zodiac G470 and outboard motor (deflated and rolled up). As it turns out I was able to take it to Alaska and Baja, before my life took a turn....now a I own a camper that seats 3, but have a family of 4 so this Unimog expedition camper needs to find another home. So whether you will want to go on a short trip to Death Valley or plan an epic surf/fish/??? adventure this is your vehicle!
Please let me know if you have any questions. For more photos see: https://picasaweb.google.com/103138229079956665377/UnimogPhotos
Goldenbora
