Unimog 404/416 double beadlock wheels 16.5x9.5 $900 Portland Oregon (can ship)
RogueFab
For sale: 4 recentered H1 Humvee beadlocks in unimog 404/416 pattern. These are the 8 bolt H1 wheels. These are all straight and run true without vibration up to 75MPH (I am running swampers, not radials... so my basis for vibration-free includes these tires). They are recentered using the Rogue Fabrication gusseted recentering kit and have half rock rings welded in. These are every bit as strong as a pressed center (with more backspacing too), and way stronger than any flat center. Backspacing is 4 inches, the max you can run with stock 404 mog drum brakes. Wheels are powder coated black, outer halves are powder coated grey.
I have a 5th wheel that has never been mounted, and it comes with an uncut mag insert if you want it. I will throw in the 5th wheel and insert.
Here is a pic I took of them today. You get 4 wheels just like this one, with used O rings and valve stems installed. All the studs are straight, the wheels have never hit a rock that I know of. 5th wheel and the uncut mag insert are not powder coated. I'm keeping the TSLs and the inserts. Inserts will cost you about $30 each. I have sources if you need them.
I will happily quote shipping, just shoot me your address and let me know if you want ground or freight, and residential or commercial.
$900 OBO. Credit cards add 3.5%. Pick up or ship from Portland, Oregon.
Thanks
Kc_trailhawk
