Unimog U1300L expedition truck
Mercedes Unimog 1300l, ex-ambulance German army => so fast axles, 90 km/h without problem
Located in Belgium
price : 92 000 euro
driving license C of course
ambulance space increased by 30 cm
registered as a classic car, must be re-inspected
turbo diesel OM366A ?
85,000 km of which I drove 35,000 myself
field-tested in Central Asia, Russia and Southern Europe
new stainless steel exhaust
double diesel tank
  • 1 new aluminum tank,
  • 1 original steel tank
  • tanks are completely separated from each other, so no contamination between good and bad diesel
  • pump to transfer diesel from one tank to another
  • old tank completely cleaned
hot water via electric boiler (on 12v and 220v)
water
  • 2 separate, separately lockable tanks of 100 liters each. When taking questionable water, both tanks are not contaminated
  • large screw top lid for filling
  • all connections at the top -> no leak
  • double filter up to 0.5 micron
  • water pump with pressure switch
  • pressure vessel/buffer vessel
  • electronic level indication in control panel
heating on diesel Webasto type, but of Russian make
  • also work above 3000m (tested at 3600m)
  • separate diesel tank (1 of the external jerry cans)
refrigerator
  • 12v / 240v
  • automatically switches to 220 V if present
counter
  • gas fire
  • disposal
  • glass worktop
  • hot and cold water, pump starts automatically with pressure difference
gas bottle under sofa
2 solar panels
  • 2 x LiFePo living battery
  • made up of separate cells, so it can be repaired
  • 12 v
  • 2 x 100Ah
  • BMS
  • solid state relays that prevent complete discharge
  • one cell is broken and should be replaced
  • charger to charge each cell separately
double bed extendable double thick mattress
table, can be used indoors and outdoors with separate base
Unimog hydraulic jack, special high model
freeze start spray
GPS, which also serves as a reversing camera, with Garmin and OpenStreetMaps maps for outside Europe
blind spot camera
relief
led bar
(reading) spots
back door (inside controls)
side door (inside operation)
additional diesel filter with water separator
LED spotlights (separate from regular (moth-ridden) Unimog lights and spotlights)
roof rack
  • spare wheel
  • bache for wheel
  • hoist system
2 safes
driving cabin
living space
current
  • 12v (in driving cabin 12v and 24v)
  • USB (also in cabin)
  • control panel with fuses, battery condition, water level...
  • can be closed centrally (with or without refrigerator)
headroom 1.85 m
6cm insulation all around
wooden floor on insulation on wooden freight floor wooden
finish, everything screwed on (so easy to disassemble in emergencies)
deadbolt lock on back door
1 single key for driver's cabin and living area side door
1 key for all outdoor suitcases
steel rims with xxxxx/xxx tires
'secret' space
shower room
shower, can also be used outside (hot and cold water)
toilet rotatable (space saving)
sink with hot and cold water
wardrobe with hangers and shelf
passage from living space to steering cabin
can be opened from living space/pilot's cabin
can be left open
new side mirror, old one is somewhere on the Pamir Highway ;-)
storage space everywhere
above refrigerator
above bed (books)
under sink/stove
driving cabin center console
extra included
battery charger Victron 24V
jumper cables for heavy duty diesel
all kinds of technical documentation
fire extinguishers
air pressure repair kit and pieces
tire repair
air filter
diesel pump with another diesel filter
all kinds of belts (not new but maintained when replacing all belts)
probably forgotten things
front portal axle breathers
new seals on all portal axles
seats in the driving cabin instead of a hard bench
Driver's seat with air pressure suspension
fabric upholstery, no sweaty plastic
roof hatch, cannot be opened from outside
Highly placed windows can be set to ventilate without being opened from outside
shore power connection
switch to fridge 240
hot water switch 240
automatic charging of living batteries
Charging the life battery is possible when driving when the starter batteries are full
large suitcase space under the bed, only accessible from outside
can be viewed from the beginning of June
I'm happy to answer sensible questions, but please don't bother me with 'what's your lowest price' and other fun-bidding stupidities.
gp01
