I recently traded for a 2000 F-450 7.3L Cab and Chassis. It was used in the Oilfield but has low miles and seems to run fairly well. It is my first Diesel. It isn't my first Dually. I plan to use the truck to haul my camper to the mountain mostly. I have looked all over the Net for Super Single rims to get away from the Duals. Most are crazy expensive for both the rims and tires. Not sure of the most cost effective rim or tire size to go with. Also the gears are 4.88's. Any suggestions on best tire hieght to make the most of the engines best power RPM? I figured this would be a really good place to ask and see what turns up. I also have been looking for a lift kit for it. Not much luck there either. I only want to go 4" at the most. Here's some pictures.
I traded a 1999 V6 Mustang for this Truck and $1500. Only wanted $4000 for the car so I figure I made out really well. Now just need to decide what direction to go. Any and all suggestions and help are appreciated thanks.
