urethane bushings for my E350 4x4
homey5230
I just purchased a 1998 ford E350 Quigley 4x4 camper van. The front end feels a bit squirrly and the steering is loose. Almost a floating feel. Any suggestions. Will urethane bushings help, along with steering component replacement I want the drive to feel secure and tight.
PhulesAU
Only if existing bushings are bad. Tires inflated ok? Play in steering shaft itself? could even be alignment issue.
Bikersmurf
Never owned a Quigley... it seemed to be a common problem from what I’ve read.
Check into Agile Off Road’s R.I.P. kit for Quigley 4WD vans. It’ll at least give you an idea where the problem lies.
Houie
