topofpalomar
Enthusiast
Hello, All,
I've been learning so much from this forum that I thought I should finally make a contribution.
For years I have thought a utility bed or a flat bed would be a great idea for a camper mount. After I found Expedition Portal I realized that quite a few individuals are doing just that. Finally, after reading about ToolBox Guy's utility bed with Skamper on his Dodge that finally pushed me over the edge. I took the plunge. My goal is to help someone who wants to tackle such a project see what I went thru and what I was able to achieve. I'm not done by any means. There is still some details to finish but so far so good. I'm pleased, and the better half seems to be on board with it.
My idea was to take my current truck, a 2006 Chevy regular cab long bed, 2500 HD 4x4 diesel and find a used utility bed to mount my older 1999 Apache popup to. I bought the truck new and it only has 51,000 miles on it. The old Apache (made by Sun Lite) we acquired used back in 2005. We have been using slide-in popup campers since 1983; this is our fourth one we've owned and we're not afraid to use it. It's getting a bit long in the tooth so if I screw it up it's no big deal really. We plan on getting a new one in a few years after retirement.
Here's what it looks like before the utility bed. Photo is from Rockhouse Canyon in the Anza Borrego Desert last Spring.
After reading about the ones already completed here on Expedition Portal and studying what I would need I realized a low profile long bed was the one that would work. I located what I was looking for at Four Seasons Truck in Colton. Dave the owner has quite a few used and new units in stock, along with take-off beds from previous build-ups. He and I worked out a deal for a used C-Tec low profile that has what is referred to as a horizontal configuration on the driver's side and a vertical configuration on the passenger side. The unit has the flip top compartments at the top which is not usable with a slide in camper on it but I could deal with that. I got the unit prepped and freshly painted, with new locks and compartment seals, a new dock bumper with new tail and running lights for less than half the cost of a new unit.
I knew that there would be some issues installing this "off the shelf" popup camper on an "off the shelf" utility bed. The jacks have to go - can't get the jacks to clear the sides. Also, the tie down bolts (being removed here) are hanging down too far to clear the top of the flip top on the utility bed, and the biggest issue will be the gas line mounted externally on the driver's side (just visible on the right along with the bonding wire). I removed the mounting eye bolts, reroute the bond wire and plan on dealing with the gas line later. I'm not going to replumb the gas - I plan on moving the camper over slightly to the right to clear it. At least that's the plan. Fingers crossed.
Here's the bed ready to go. Notice the longer, horizontal compartment on the driver's side and the short horizontal compartment on the passenger side. I've got plans for those guys!:wings:
The old bed sits in the foreground while the utility bed is installed.
Finally, the completed job, no tailgate needed. Weight is approximately 450 to 500 lbs more than the standard bed.
Next, drive back to Palomar Mountain and entice the boys to come up and help the old man get the camper installed. More to come....
