Vector Offroad's MP Table
Vector OffRoad
Supporting Sponsor
The Vector Off-Road MP Table (Multi-Purpose Table) installs to any vertical surface with a minimum surface area of “29-1/4” x 11-1/16” for our 28" table. Our 22" table installs to any vertical surface with a minimum surface area of “23-1/4” x 11-1/16”. When stored in the closed position the table only protrudes a maximum of 1.25” from the mounting surface.
Designed to provide maximum usability in a light weight and slim package, the MP Table incorporates ¼” holes and slots to allow the use of QuickFist™ Clamps and Molle Straps for mounting trail gear, tools and pouches to the table. There are also convenient holes along the outer rim of the table for hanging your cooking tools if you are using the MP Table as the base of your kitchen. To quickly deploy the table, remove the two knobs on either side of the table, fold the table down, and place the knobs back on the studs.
The MP Table is laser cut and manufactured in the USA from aerospace alloy aluminum. All of the mounting hardware is high quality stainless steel and is easily field serviced. Even the cables are 100% stainless steel and polymer top coated to further prevent rust and fraying. The MP Table will provide you with many years of trouble free service.
The MP Table is sold standard in a black wrinkle powder coat finish.
http://www.vectoroffroad.com/mp-table-22-p-47.html
http://www.vectoroffroad.com/mp-table-28-p-36.html
Vector OffRoad
Supporting Sponsor
We have never formally tested these tables on Rover's, but we have had some feedback from Expo members that believe they will work with some models.
28" MP tables discounted 15% now through 10/31. Use coupon code OCTEXP.
dhuss
