Vehicle Security Measures
Scott Brady
Founder
Many of us have invested significant time and money into the building of our vehicles. It is also likely that we leave them unattended while doing hikes, mountain bike treks, or shopping in a small village.
There are a few basic measures that can be taken, and then several more advanced solutions:
1. Basic Prevention:
a. Make sure that all doors are locked, and windows up
b. Make sure that no items can be easily grabbed from the bed, etc.
2. Intermediate Prevention:
a. Many vehicles have factory alarm systems with ignition kill. Make sure you know how to engage and disengage the system
b. Visual protection, like a steering wheel lock
3. Advanced Protection:
a. Full alarm system, with ignition kill
b. secondary door locks
c. Window screens
d. Proximity alarms
What have you used?
BajaTaco
Swashbuckler
One day I went to a local store to get some things. When I came out to leave, my truck wouldn't start. After a lot of troubleshooting, I couldn't figure out what the problem could be. Finally, I walked over to a parts store and bought a new fuel filter. I laid under the truck in the parking lot with a drip pan and changed out the filter, hoping that would do the trick. No luck. I ended up walking home and making arrangements to have the truck hauled to the dealership by a wrecker. The dealership spent hours trying to figure out, and finally fixing the problem. So what was it? A failed security device made by Clifford that I had installed on the truck when it was new. I can't stand audible car alarms (especially when out in the backcountry), so I thought a system-kill device with a computer chip was a good solution. Never again. This device was set up to disable the vehicle from starting, and it worked by means of a "key" that was a pin inserted into a switching device. The chip in the key is always changing codes along with the switch, so the key becomes unique and will be the only key to disable the device. Obviously, something on the unit (computer) failed. And had this happened while I was out in the boonies somewhere, I would have been screwed.
Brian McVickers
Administrator
Staff member
We also tend to have more stuff hanging off of our vehicles than your average car. Precautions should also be taken to secure these items if you can't stow them inside.
Cables and or Padlocks along with special holders can be applied to:
Hi-Lift Jacks
Shovels
Axes
Water and Fuel Cans
Spare Tires
(Note - make the cable substantial, at least 1/4" braided steel, anything smaller is just too easy to cut through with ordinary tools)
Also
D-Shackles should be more than hand tight so that it would be difficult for someone who is just walking by to stop and take it off your vehicle by hand with no tools.
Make sure your winch clutch is always locked or set to non-free-spool. This will prevent someone from grabbing the hook and just pulling the cable out. (Note that this one is more intended to prevent vandals or people just screwing around, If they are the type to do that hopefully they don't know what the lever is for anyway!)
CB or HAM radio Antennas
Would be great to secure some how even it you just tighten them so that they can not be undone by hand.
A lock for your towing hitch receiver to secure the ball mount or recovery point you have in there.
In addition always try to hide, cover, remove or properly stow anything of value or interest that may be inside the vehicle. (A neighbor recently caught some kits walking around the neighborhood pressing their faces up to the windows to inspect the insides of vehicles to see what might be worth breaking a window for!)
Hltoppr
El Gringo Spectacular!
Hey Scott!
You forgot parking inside the hotel!!!!
-H- :victory:
Hltoppr
Actually, when our motorcycles were parked outside overnight, we would empy the panniers and cable lock the rear wheels/frames together.....
More deterrent than anything, but then again we were usually parked on the front porch of the hotels, etc. (Con permiso...)
-H-
goodtimes
Expedition Poseur
From my vast (haha) experience, there are 2 kinds of thieves to worry about. Those that want to make a quick buck by selling stuff they stole, and those who want your vehicle.
The first type are going to grab whatever they can in less than 2 or 3 minutes, and get the heck out of there. They will target things like your cd player, sunglasses, gps, etc. They don't want large bulky items as they draw to much attention (which is why my kayak and cooler were about the only things of value that were left the last time my jeep was broken into). The best defense from these guys is to take everything inside with you at night, and cover it the rest of the time. If the next vehicle looks like it has more stuff to steal, they will target that one instead of yours.
The second type of thieves are harder to deter. The stakes are higher, so they will take more time to get what they want. Audible alarms are annoying....does anyone ever look to see what is going on when they hear one go off? I don't......I like visible deterrents. Steering wheel locks etc give the thief a heads up that he has a little bit of work ahead of him. Hopefully they will move on....if not, ignition kill switches are good. The jeep has a factory installed system that works pretty well. Once the engine starts, there is a RFID chip in the key...if the chip doesn't send the correct signal back to the computer within 2 seconds of the vehicle starting, the engine shuts off. Factory installed systems are pretty reliable....I (like Bajataco) don't trust aftermarket systems. They make me nerfous. But, a simple switch can be wired in series with the ignition switch....turn the secondary switch off, and the electrical signal from the ignition switch to the ECM gets interrupted...so it won't start. If the switch fails, just pull the wires off the back and connect them to each other....the switch has been eliminated. Mount the switch where ever you like (under a seat, under the dash, in the glove box....). This will render your vehicle about as safe as you can get it. At this point, they will need a tow truck to get it from you. Which brings up a bit of food for thought.....if you are at the end of a road, getting ready to go for a hike up to some point of interest.....you see a tow truck pull up to a truck and proceed to load it and tow it off.....what is going through your mind? I'd bet that you are thinking "that sucks...some body's truck wouldn't start so they have to pay to have it towed out and repaired".... but really....what is to say it isn't a thief towing it off while the owner is out hiking/backpacking?
asteffes
Pulling the fuel pump fuse is an uber-tactical security tool which I have employed more than once. Ok, it's not super-sly, but it's an idea, and I have done it for security reasons.
I think the most obvious bit of advice is to keep as much stuff out of sight as possible, and lock down anything that you cannot keep out of sight. If they *really* want your rig, they'll get it somehow.
The '05+ include an engine immobilizer, which works automatically with the factory keys. The ECU simply won't fire the ignition until a factory key with the correct rolling-code is used to start the truck.
Scott Brady
Founder
I have the factory Toyota alarm, which is actually pretty nice. It disables the ignition. I also have a steering wheel lock. All of the exterior items are locked and the rear swing-out can be locked closed. The platform I made went a long way towards securing my gear.
goodtimes
Expedition Poseur
BajaTaco said:
While people participate in this thread, just keep in mind that the info you share can be read by just about anyone. ;)
Good point...
I have a shotgun shell stuffed into a steel pipe pointed at the drivers seat...rigged to go off and when someone tries to steal my stereo again. All you thieves keep that in mind. hehehe....
60seriesguy
Vehicle Security is a great topic, one often ignored during expeditions, sometimes with drastic consequences. A few years ago a couple of TLCA members were surfing off a remote beach in Baja California, and when they returned, they found their Land Cruiser gone, along with all of their equipment.
Being originally from Venezuela, my Land Cruiser is equipped with what was state-of-the-art security in 1990 and remains overkill for most US applications. Most of the security devices listed below are mechanical in nature because of the intended use of my Land Cruiser. None are completely theft-proof, but are designed to complement each other and simply make the vehicle as least attractive to thieves as possible. This isn't to say that the truck can't be stolen, simply that it's going to be much easier to steal the next truck than mine. Among these are:
1. Shifter Lock + Shifter Collar. This device manually locks the shifter in reverse and prevents the shifter from being pulled out or removed.
2. T-Case Lock: works in conjunction with the above (single key) and manually locks the t-case shifter in low gear.
3. Pedal Lock: Locks the brake and clutch pedals together and prevents them from being depressed.
4. Fuel Cutoff/Anti-Carjack: Mechanical device located on the floorboard (under the firewall), allows cutting off fuel supply
5. Hood Lock: A low tech section of re-inforced steel chain that drops in front of the radiator and locks to a welded tab on the frame.
6. Two separate electrical cutoff switches
I don't have pictures here in the office but I'll post some tonite.
On expeditions in remote areas, VISIBILITY is what usually gets us in trouble. If people can't see your gear, they'll be less prone to grab it, even if they assume that you have it. Thus, it's always important to have gear stowed/out of site when you park for fuel, and especially important to keep gear stowed away when you're camping and out for the night. You might *think* you're remote and miles from anyone else, but I've had stuff stolen from our campsites in South America in very remote areas, nothing is ever really safe. Most of the time it's a crime of opportunity rather than one being actively targeted.
I second the notion of securing jacks and spare tires and suggest taking it a step further. When on expedition I run a cable through the handles of all my jerry cans, not only while they're on the rack, but also when they're on the ground. The cable is long enough that I can run it through either the trailer's wheel or through the legs of chairs/tables and cooler handles. In some areas, this isn't necessary, in other places, it's the only way of keeping stuff around. Again, this may not deter a dedicated thief, but will keep crimes of opportunity at a minimum.
On my trailer, I padlock the steel lid (which prevents the tailgate from dropping) and keep a lock on the lunette hitch when the trailer is not connected to the Cruiser. Even when they'e connected, I run another cable from the trailer's tongue to the Land Cruiser's rear bumper.
Great topic!
Hltoppr
Henry, I've admired your vehicle for years, and used it as a basis for some of my expedition type mods....!
Cheers!
-H-
Pskhaat
2005 Expedition Trophy Champion
A simple device I have worked out on my FZJ80 is a manual `enable' switch between the brake pedal switch and the Automatic Park Lock. You can enable default functions through a momentary switch. Very easy to do. I would not rely on this alone of course, but this may delay any theft by at least a few minutes to track it down.
When leaving my vehicle for a long time I also often pull the high-tension wire between coil and dizzy. Hard to source that one when trying to steal a vehicle.
A manual fuel valve I'm sure can also delay any theft and has other benefits.
I gotta believe with a few deterants theft of the vehicle itself (the largest real asset) can be 99% succesfully avoided.
xander69
