Vertical Tire Mount Ram HD $225 6 months old.
watrboy
I am selling an AEV Vertical Tire Mount for Ram HD. I needed it for a trip and used it in a different full size pickup. Drilled 2 holes and everything else worked. Also has the larger Wilco Cone. I am near Billings Montana along I90. Heavy, but I can work with shipping.
From the AEV webpage:
AEV’s Vertical Spare Tire Mount is a vehicle specific solution for securing your full-size spare in the bed of your HD Ram truck. Each vertical spare wheel mount is fully adjustable to accommodate a range of tire sizes and features a robust tubular steel frame that securely attaches to both your truck’s forwardmost bed rail and the floor of the bed to safely hold your oversized wheel and tire in place, even on the roughest off-road terrain.
AEV’s maximum recommended tire sizes for each application are as follows:
  • 2003+ HD Ram: up to 42×14.50
Careful attention was also paid to ensure that the overall height of the mount and tire would be compatible with the installation of most aftermarket toppers. AEV’s Vertical Spare Tire Mount for truck bed also features additional provisions for accessories such as a sand flag or CB antenna, as well as a convenient spot to hold a shovel. E-coated and powder coated for maximum protection against the elements and proudly made in the USA.
Please note: If you are using an aftermarket wheel with a hub bore larger than 3 5/8″ with the Ram Vertical Tire Mount, we recommend also purchasing Wilco Off-road poly cone part number# UC60702. KEY FEATURES:
  • Available for HD Ram.
  • Vertically mounts your full-size spare tire securely in your bed
  • Robust, tubular steel frame designed for off-road use
  • Adjustable to accommodate a wide range of tire sizes
  • E-coated and powder coated black finish
  • Proudly made in the USA
Mitch Bears
