Vertical Water Tank Info Wanted
Jwalker
Does anyone know of a flat vertical water tank built for a full size pickup bed that stand up in the front of the bed against the cab. I found a few poly tanks that are made for the inside of rovers and the like and so they are only about 53 inches wide, 4 inches thick, 25 inches tall and hold about 13 gallons. Plus they are all australian sold. I am looking for a poly or aluminium tank 62" wide 4" thick 20" tall with a top fill port that is sold in the USA.
Jwalker
thanks Martyn, but that is one of the ones I saw already. The dimensions are just a bit off, I need it wider and shorter.
Martyn
Closest I have in Poly tanks are:
26 gallon - 60 x 21 x 6 $485.36
28 gallon - 60 x 16 x 8 $508.21
33 gallon - 60 x 22 x 9 $539.48
50 gallon - 64 x 22 x 9 $704.28
Fittings are additional and can be placed per your requirements.
4xCoffee
