Vinyl Flooring for the 2006 Unlimited
Beowulf
Does anyone make a Vinyl floor that would fit an LJ? I believe Mopar has a nice one for the 2007's, and I have seen them for TJ's, but I have not been able to find one for the 2004-2006 unlimiteds.
BIGdaddy
your right, come to think of it...i haven't really seen an all weather option for our rigs...
rhino-line?
thejafe
Ya know, I considered those vinyl Mopar mats myself for awhile but decided against. If moisture gets trapped between the tub and the underside of the vinyl you're asking for rust.
roadkill
I have never seen these before but if they have the little raised buttons on the underside I would think there would be enough airflow to allow it to dry out fairly quickly. I have had the rubber bedmats in pickups for years without any issue. even had corn, hay and mud trapped under it without any rust problems popping up. the spray on bedliner like Rhino or Line X is the best solution but the vinyl floor liner has to be a step up from the carpet that has all that padding that will retain and hold the moisture on the tub like a sponge. it also can mildew and stink over time if it gets wet and stays wet enough times. if I can ever get a first hand look at the vinyl liner or see pics of it installed I will probably go that route on my jeep. I think it would be all the protection I need and a 1/4 the cost of a professional bedliner install.
