Volvo C 303 / TGB 11 Expedition camper project.
tgblars
Hi I`m new here and lives in Norway Europe, but just wanted to show you guys my project / expedition vehicle.
The truck is a 1975 Volvo C 303, in military terms its called TGB 11. It has portal axles an locks on both front and rear axle, its awsome in most terrain, it has a ground clearence on 42 cm / 16,53 inches with 36 inch IROC tires :)
My plan is to remove the original B30 six cylinder gasolin engine and mount a Mercedes OM 606 or 603 six cylinder diesel engine and a 5 speed TGB 20 gearbox to get lower rpm at highway use.
I will also cut away a section of the roof and build a Flip pac like roof to gain more space and to get a queen size bed inside the roof section. 4 seats and a table will also be fitted along with som extra storage space, drawers etc.
It will also be fitted with a sink, some propane burners and a refridgerator.
10378064_324483921046613_403519619575935918_n.jpg10357701_333419276819744_7437618271213036467_o.jpg10525833_325055157656156_1086600334265812261_n.jpg
Hope you liked my rig...More info on this project will come soon...
Regards Lars
tgblars
Here is the engine I was planning to put in to the truck... 177 hp Mercedes diesel.
A sink and somewhere to cook is important :)
I have also bought a fridge like this, whitch runs on Propane, 12 v or 220v
I will try to make a pop up roof solution like this, does anyone have any experience with this solution? Is it sturdy enough in windy and snowy conditions?
Haf-E
You might reconsider the flip pac type roof tent and do one which goes up with a hard roof. Much better in rain, snow and wind - which I hear Norway gets a bit I hear.
You should also check out the other website which focuses on c303s & pinzgauers - www.real4x4.com as there are a couple of c303 builds very similar to your idea.
tgblars
Thanks I will check it out :)... hmm... mabye you have a point there... I like the Flip Pac design beacause of the extra space you get with the bed inside the roof... but I have also considered the hard roof solution...
Haf-E
I've seen popup tops which have the bed connected to the roof so when you first open it you have lots of space to stand - then the bed can be lowered for sleeping.
Andrewkawa
Hi Lars,
I am curious to know how your engine swap has gone. Perhaps it would be an option for mine as well.
Gr. Andrew
