Looking for a safety device roof rack for a disco II it can be from a disco I as well, also looking for after market bumpers front and rear for the disco II along with rock sliders and armor for diffs, steering and gas tank.
Thanks in advance, Travis 619-933-7168 call or text is easiest I'm in San Diego.
You do not want one for a D1 it is shorter by about 8" and will be hard to access off the back as it has to fit from the windshield end... If you are planning anything heavy duty, save yourself the trouble and get a Hannibal aluminum rack. These are flat, have support the whole length of the gutter and work great. SD rack will fail with loads off road. There are reasons the Camel Trucks racks were bolted to the cage and not the gutters... Gutter mounted racks can not take all of the vibration and flexing for very long...
I run an ARB on the front of my D2, highly recommended
Sliders I have from Roxtarfab.com talk to Brad, he will take care of you. These are not only mounted to the sill, but to the chassis as well. 160lbs of try and break me
. I use Southdown skid plates on my steering, front axle, rear diff and tank...Best you can get although I had to modify my front steering guard mounts to clear the ARB mounts. Just a notch was all. I would also recommend Old Man Emu 2" lift....Best money you will ever spend on the truck... Good info on Roversnorth.com D2 forum and Landroversonly.com D2 forum... See you there.
Chuck Prowse
1996 Disco Trek 4 and Camel selections
1998 Disco LSE Anniversary
2003 Disco SE7 expedition prepped
1987 110 300tdi/R380
1969 Series 2A 109
