Warn M8000 mounting bolts
psykokid
Looked at the warn parts diagram and they don't have the bolts that mount the motor to the drum support listed. Anyone know off hand what the size/thread pitch they are? Going to mount the albright contactor I picked up to replace the solenoid pack to the end of the motor and will need to get either bolts that are a little bit longer or just use some threaded rod and nuts to secure things. I haven't taken it to bits yet so figured I'd check in here and see if anyone knew off hand.
I'm not sure how far the current motor bolts extend into the drum support. The bracket on the albright contactor is maybe 1/16 thick so I MIGHT be able to get away with just using the stock bolts but i'd rather know the motor is mounted securely to the drum support than risking it and have it strip out the drum support.
Looking to do this:
