Take the gear train off and check the sliding collar inside. Might have got some moisture in there causing it to want to seize. If that's the case, make sure you get the grease Warn recommends. Greases like red #2 tend to cause suction and that leads to the problem your having now. Hope this helps.
Lator.....
