Warn VTC Compressor
PNWINFERNOPRO
@PNWINFERNOPRO
Purchased new less than a year ago; used 4 times. Includes battery clamps, dual air filters and Powertank coiling air hose. All in excellent shape.
In Kirkland, WA
$500
Warn 75789 Air-Power VTC On-Board Air Compressor 12V DC 125 PSI 1 Gallon Air Reservoir
With an abundance of power from its high-horsepower fan-cooled motor, V-twin configuration, and large one gallon integrated intercooler and reservoir, the Air-Power VTC is the highest-performance compressor in the WARN Air-Power lineup. The VTC is ideal for powering air tools, rapidly airing up everything from tires to rafts, powering air suspension systems, and just about anything else that needs air. It comes with a removable carrying cage so you can easily transport it or hard mount it to a vehicle or trailer. A pressure cut-off switch turns the compressor off when it reaches 100 PSI and back on at low pressure. Add to this a quick-connect hose outlet, and you've got an ultra versatile compressor. With all this power and all of these features, the VTC is a force to be reckoned with.
Power: 12V DC motor Amp Draw: 140 amps peak when new, 125 amps after initial break-in Maximum Pressure Rating: 100 PSI (670 kPa) Airflow Rating: 20 CFM @ 0 PSI; 8 CFM @ 90 PSI; (566 l\min @ 0 kPa, 226 l/min @ 620 kPA) Intercooler/Air Reservoir Size: 1 gallon (3,78 liter) Weight: 50lbs
Goldenbora
