FosterWV
Baller On A Budget
Just curious you guys thoughts on a water faucet idea I had for my trailer.
Water will be for cleaning dishes etc, not drinking not showering.
Thinking about mounting a "pot filler faucet" above the fender and placing a collapsible tub on the fender. Then supply the faucet using a 1 gpm 3/8" pump from a 7 gallon water jug. The faucet folds flat to the wall when not being used and traveling.
Would 1 GPM be adequate?
What brand pump do you suggest?
Idea behind the 7 gallon portable jug/container is that it's easy to take out to refill plus I have no room under the trailer for a permanent tank.
Link to the faucet....
Aquafaucet Wall Mounted Pot Filler Kitchen Faucet With Double Joint Swing Arm Brushed Nickel https://www.amazon.com/dp/B014CSGBHG/ref=cm_sw_r_cp_tai_i_RZjgBb236NX6D
Link to pump.... my cost $28.99
https://m.northerntool.com/products/shop~tools~product_200631750_200631750?adv=true
Trailer pic for reference
Thanks
Thanks
