ab1985
I'm putting together an onboard water setup for my 4Runner. I've got everything and want to install it later this week, but one question I need to address is where to mount the water pump. I've relocated some things on the driver side wheel well under the hood to make room for the heat exchanger and I've got plenty of space, but I'd rather keep the pump inside the vehicle. It's a 3.7 GPM variable speed Jabsco and instructions say it can lift water 9 ft but I'm not sure how that equates to horizontal distance. If I mount it in the rear of the truck it will pull water from the tank 2-3 ft away (where the spare used to be), pump it 8 ft forward to the heat exchanger, then 8 ft back to the faucet. If I mount it under the hood it will pull water from the tank in the rear 8 ft away, push it through the exchanger 1 ft away, then push it 8 ft back to the faucet. I contacted Jabsco and Shurflo and neither was very helpful.
What say you, expo? What needs to be taken into consideration when laying out your tank, pump, heat exchanger, and faucet locations as far as distance and pump capability?
Thanks!
Thanks!
