Superduty
SCROLL DOWN TO POST 5 FOR WATER SEALING DISCUSSION.
I have an ARE contractors shell on my truck. I am going to make a low profile rack out of out 1.5x1.5 8020 aluminum. It will sit about 1/4" about the roof of the shell. The rack will hold a solar panel and an Alu Cab Awning.
I plan on bolting it to the top of the shell. Which method below is better? I assume option 2 is stronger, but I also think that will be considerably hard to make accurate holes to line up with the aluminum frame. Assuming option 2 is stronger is it that much stronger to warrant the extra hassle?
Any other suggestions in terms of bolting it are welcome.
Any suggestions or tips or tricks on getting the rack (large rectangle 4'x8') lined up and marked for drilling?
I will bolt to the aluminum framing.
Option one is to use a carriage bolt and slide it into the track of the 8020. This will likely be easier overall as I only need to get one direction correct in terms of the hole in the aluminum frame, then the carriage bolt slides to the correct location.
Option 2 is to use a carriage bolt and through bolt it all the way through the 8020.
Thanks for your help.
