Water system questions for (from) Dummies
JMacs
So I found a trailer on Craigslist that is cheap enough that I think I can finally start my build. The idea is a small, dedicated trailer to carry all of our camping and kitchen stuff. I want to include a sink in the kitchen area, but I have some questions.
I am planning on installing a Shurflo Revolution pump. The way I understand it. You have a switch that turns the pump on. It runs constantly pressurizing the water at the tap. It has its own internal pressure bypass that allows it to keep running without either burning up or over-pressurizing the system. When you are done, you switch the power off. Correct? How long can you leave the pump on without burning it up?
The plan has the water tanks installed under the bed of the trailer. Create a metal support and metal tray. Try and make it easily removeable or accessible from above if I ever need to get at the tanks. Question for those of you who have done it. How did you handle the drain line? In most of the diagrams I have seen, there has been a drain valve to completely empty the tank. Did you just stick it out the side? Or did you install it at all? Is there something you would have done differently if you were going to do it again?
And yes, there will be 2 tanks. One for cold and one for hot. I want to install a drain-back solar hot water heating system. There are some really simple ideas that I have seen that involve making a shallow box with a clear top, 60’ of coiled copper water pipe, and some black paint. (of course, I can’t find the pictures on the web right now.) Install a diverter valve from the water pump and circulate it up to the roof of the trailer. Ta-da. Hot water. Only downside is that I will have to either make sure it is really well drained in winter, or make it removeable.
The last question. What do you do with the gray water coming from the sink? Drain it onto the ground? Collect it in a buck and the go pour it out in the grass?
chiplee
And yes, there will be 2 tanks. One for cold and one for hot. I want to install a drain-back solar hot water heating system. There are some really simple ideas that I have seen that involve making a shallow box with a clear top, 60' of coiled copper water pipe, and some black paint. (of course, I can't find the pictures on the web right now.) Install a diverter valve from the water pump and circulate it up to the roof of the trailer. Ta-da. Hot water. Only downside is that I will have to either make sure it is really well drained in winter, or make it removeable.
There may be pumps like that, but the one I used recently just turns on when it senses demand/pressure drop on the "out" side of the pump. You turn on the faucet, and the pump starts pumping to supply water, and you don't need a special faucet with a wired switch or anything. My pump has ever ran automatically to maintain pressure since I installed it. Since it's sealed it doesn't lose its prime, but even if it did, it can dry prime without damaging itself, and it draws 3 amps and takes like 2 seconds to prime. I don't think it would ever burn up or hurt the battery. I don't think it would ever run on its own until you turned on the faucet or your hoses developed a leak on the exit side of the pump. There's a thread here about how I went about adding running water to my trailer. I do have a main power disconnect for storage. On my trailer the gray water just drains into a bucket to be dumped or used elsewhere. Good luck, sorry I'm no help on your other questions. http://forum.expeditionportal.com/threads/168130-Kamparoo-electric-water-pump
ilciclista
