Dan Grec
Has anyone ever seen a drinking water tank mounted under a JKU, between the frame rails, on the opposite side to the stock gas tank between the exhaust and drive shaft?
I'll relocate the evap canister, which gives a lot of space.
Obviously I'll put a stout skid plate on it, similar to the stock gas tank.
Front runner has a 60L (15.9Gal) tank that I think would just fit, though it will hang down below the frame rails.
http://www.frontrunneroutfitters.com/water-solutions/water-tank-60l-840l-x-360w-x-220h.html
Ideally, a tank would be a little shorter - only 7" high or so. If it were something around 35"x12"x7" it would be ~12.7gal (~50L)
Has anyone seen this done, have pics, or suggestions for a tank?
Thanks,
-Dan
Thanks,
-Dan
