I mounted mine on a rubber mat and used Home Depot strapping bolted through the tub. I cut strips of the same rubber mat to go under the straps so as to not damage the tank. Mounts solid and does not move. I am going to build a plywood shelf to go on the top to protect the tank and more importantly the fittings.
Water fill fitting is a marine unit in a home made aluminum bracket. Vent is in the same spot and it works awesome and keeps it secure from tampering inside the tub.
Super happy with the way this all worked out.
Four D rings one on each side and ratchet straps would be the way I would go. This way is nothing too permanent if you have a need not to have the tank onboard.
Ride it like you stole it!
I would think you would be happy, that is exactly what I wanted to see (looks to be the same box I purchased) and where I am headed. Why did you mount what looks to be your primary access hose on top? I plan to mount mine at the bottom so I could simply the pressure of the water to push it out if the Flojet was not in use. What type of strapping is that??? I did a search on HomeDepot and didn't seem to come up with anything like that.
Do you think this method would work as well for two deep storage batteries and did you put some batteries in your build?
Pretty much did. Guy sold me the trailer for $500.![]()
