Water Tanks
Does anyone know of any overlanding, offroad, or RV shops in the Orange County area that might sell and install fresh water tanks on trailers? I have an M416 cargo trailer and am planning on installing a water tank either in the storage tub or below with a fresh water fill inlet and spray port outlet. I’m doing away with the Jerry cans and rotopax containers… would prefer a more permanent, larger capacity water storage solution with a water pump. It looks easy enough to DIY, but I’d like to see if a pro might be nearby that can make it happen within a reasonable price range. Any suggestions are appreciated. Thanks!
Peter_n_Margaret
I make my own tanks by fabricating steel sheet moulds and then having the tanks rotomoulded from medium density polyethylene. They are suitable for water or diesel.
For just one or 2 tanks, they are easily fabricated from HDPE sheet by hot bending and hot air welding. Any size or shape you want. MUCH more durable than aluminium or stainless steel and lighter.
Talk to a local plastics fabricator.
Cheers,
Peter
OKA196 motorhome
1000arms
You might want to look at Ronco Plastics marine tanks. The make marine water tanks and marine waste tanks. The difference between the two is the in the inlet and outlet configurations. The can also be obtained as "blank" tanks. The rectangular tanks have dimensions listed while the non-rectangular tanks show "see diagram". I don't know if you will be able to buy directly from them, but they are in Orange County California.
Click "about us" for a map:
Errant
I use a baffled 15 gallon Valterra tank with a Valterra hand pump in a Uniseal flexible bulkhead on my M100.
