pete.wilson
hey
I have an older trailer that I had bought which is 4.5 X 8 ft long, 16 in high sides, very stout, heavy duty frame, very stable at highway speeds. The axle required 2 1/4 bearing buddies (not 1.98in ones) and the tires used to be 5.30 X 12 but I now have the ST175 X 13 which are rated at 1100 lbs capacity. Is the trailer weight carrying capacity rated then for the 1100 lbs. or is there another formula taking into account two tires? I believe this is less than the original weight capacity on the frames data plate which I belive was around 1200-1300lbs. Also can the axle be flipped over to gain more clearance (spring over)? Thanks all.
