Welding on the Montero frame
Dereksd
Will welding on the frame of my Montero fry the computer or anything? I know how sketchy car computers can get. Figured I would ask and rather be safe than sorry.
IncorpoRatedX
If you'd like to be safe, unhook the negative terminal from your battery before welding. I've welded a ton of stuff without unhooking anything though.
jeep-N-montero
It's just like any other vehicle, unhook the battery and make sure you remove the carpet above the area you intend to weld, and keep a spray bottle handy for flareups.
v_man
sometimes if I can't find a good place to clamp the ground near where I'm welding , I'll weld a small tab to the frame very close to where I'm welding and ground it there , then you just knock the tab off when you're ready to move on .
Sabre
Overlanding Nurse
By following all of the above suggestions I have welded a fair amount on both frame and body and have never had any complications.
iStan814
