Do you know if the Rotopax are DOT approved?
I see you are in Ca.
Jeff
I think CARB is the regulatory agency for gas cans, found this on the Rotopax site:What's a "CARB" can?
CARB stands for California Air Resources Board. They established environmental requirements for portable fuel containers in California. Some other states have also adopted these requirements. U.S. EPA plans to adopt similar national requirements in January 2009. No-Spill meets these requirements with the following features:
1. An autostop, self venting nozzle that stops the flow of fuel when the target tank reaches full.
2. A single opening for filling & pouring. No separate vents or openings.
3. A treated can body for very low permeation.
4. Automatic closure. Nozzle automatically springs to the closed position when not pouring.
What's the difference between No-Spill's CARB cans and regular (non-CARB) cans?
No-Spill's regular (non-CARB) cans are very similar to our CARB compliant cans. After changes in CARB regulations effective July 2007, the only difference between a No-Spill® CARB compliant can and our regular (nonCARB) can is the special treatment of the can body for low permeation. By January 2009 the US EPA will require that all fuel cans comply with new EPA regulations (similar to CARB) so our regular (nonCARB) cans will be discontinued and No-Spill® will only produce our CARB/EPA compliant version which will include Child Resistance features required by CPSC in January 2009"
The cans they sent me I think are the non CARB Cans, they have the spout with a stopper and a threaded ring that has the spout into the can closed, and pointing out of the can opened. On the opposite side of the can there is a typical 3/8" or so vent with a cap.
I have several of the new type spouts and the SUCK!!!! They are cheap, a pain to pour from and they leak. I have a 5 gal metal blitz can in my bed (under cap) and after a day on the trail, it reeks of gas. I cant wait to get the Rotopax mounted!
Kye
