What hose is this? Jeep's sprung a leak!
Caoboy
It's the hose with the electrical tape bandage that got me home. I believe it's supposed to go to the heater? Not sure though. It doesn't look factory. Pictures are how it's routed. I'm thinking the previous owner did it as a fix to either a leaky core, or just because the climate control doesn't turn on low or high speed.
If it just goes to the heater core, would I be safe to just cap them off somehow? That hose isn't working well, as it not only sprung a leak, I can feel it being worn through where it touches the valve cover.
It's a 2.5 engine in a 1991 YJ in case y'all don't know.
(crossposted on JEEPFORUM as well)
bob91yj
Resident **************
Generic heater hose. Yes, it used to go to your heater core. I'd guess the heater core started leaking, rather than fix it the previous owner by-passed it.
Caoboy
The question is, dare I just loop the hose, or fix the heater core? :D
I thought that was what it was. I'll start seeing what's the better option. I don't think the fan speed control is working right now either.
Caoboy
Edit, might as well start fixing what needs fixing, no need to half *** it, i'll start with a new core and diagnose what's wrong with the fan control.
bob91yj
No harm in keeping the hose looped like that if a heater core isn't high on your list of priorities.
Hill Bill E.
Oath Keeper
Put a new 'loop' on it for now.
The heater loop is also a bypass for when the T-stat is shut, so you don't want to just cap off the ends.
XJ heater cores are a pain to change, plan on a full day for it.
Caoboy
XJ? I have a YJ. I've read it's an hour tops. I don't even have to pull out the old hoses from the core! :p
Picked up a core and hoses today from the local parts store. I'll put it in this weekend. Then I can test drive it and see if anything else decided to spew Hulk Juice.
It looked like the whole bottom of the water pump was leaking it's guts out!
