what is part number connected to brake line and rear diffrential
newworld2004
Hi, all
please see attached picture, I need to replace the part which is connected to brake lines and rear differential, it is rusted out, so not sure what part/s do I need in order to replace them.I don't have leaks yet , but it is preventive maintenance .
Toasty
Buy a straight and bend it to fit, it's really easy. I can't seem to find a part number with the web based app. Maybe someone still running CAPS can find it.
newworld2004
Thx, Toasty.
I am afraid, because it is rusted out may not be able to remove it. what is that round nuts that hooked up to rear differential? do I need to replace that as well?
freewayross
Thx, Toasty.
I don't think you have to change that distributor. The distributor itself should be fine, but you need to change the brake lines. They will develop a leak eventually and it's dangerous. We just did that 2 weeks back on my Gen 2.5
Buying Factory lines is a rip off, buy the lines from an auto store and rent the bending and flaring tool from the same store.
newworld2004
Thx, Guys.
just to be clear . I still can by pass distributor and run rear brake lines?
freewayross
Thx, Guys.
Why would you want to bypass the distributor? There is one line coming in to distributor from LSPV, and the distributor is to distribute equal force to both rear wheels.
If your rear brakes work, keep the old distributor and change the brake lines only.
newworld2004
do you have some diagram so I know what is what , beside I am afraid can't get existing lines replaced since it is rusted.
Houie
