What is the best way to protect the trailer frame?
smlobx
Wanderer
I just picked up a nice Dinoot extended trailer.
The frame is well built using 2x2 square channel and 1x3 C channel. The frame is just raw steel and is showing some superficial rust and I'd like to have it sandblasted then either powder coated or Line X'd.
What would you reccomend and why?
Thanks!
JoshN
POR-15, then cover it with any old spraypaint. You will only need 1 qt of the POR-15. Stuff is hard as tank armor after it cures, but fades from UV if you dont paint over it.
smlobx
Wanderer
Josh have you ever used it?
In reading the info on the website it says that if you do the three step process you can apply it directly over metal with rust on it...is that true?
tarditi
JoshN
I did. It is the coating for my camper frame. Self levelling too, so brushing it on end up looking like a gloss powder coat. However in my case I had my 60yo frame media blasted first because i had some fab work done to it before coating it. It is straight on bare metal though, no primer.
Psyph
