What should I do, I have a 1963 land rover 88 which is in rough shape
Tgrassdr
So I bought a land rover 88 a couple of months ago. It needs a lot of work. The engine is seized, it needs a front drivers side fender, tires, basically a full restoration. Is it worth it.
:coffeedrink:
ZG
Busy Fly Fishing
hmm... I would say it depends on your skill, your wallet, your resources, and your personality. How is the frame and rest of the bulkhead?
corfuchris
It's always worth to safe an old Land Rover, depends on space, time, money dough.
I'm selling a few parts from a 1960 SII in case you need something.
My SII was in very bad shape
wood in the frame
but I made a new rear crossmember
and rebuilt the frame
Keep your old Series, if not you'll regret it one day.
Cheers, Chris
Dawgboy
You bought it for a reason, what were you thinking? I would think to rebuild. I would also love to see pics.
Brought to you by Cyberdyne Systems
Decision by consensus ? Most all restoration projects undertaken by individuals are not based on rational thought but rather a yearning/drive that defies rationalization. Seemingly if you ask the question you lack the yearn/drive to undertake the project.
evilfij
There was only one rover engine I could not get running and it was a 1.6 IOE in my 51. Way too much rust in the cylinders.
If I were you, I would pull the plugs and dump a releasing agent (Marvel mystery oil, PB blaster, even ATF) put the plugs back in and let it sit for a week. If it won't turn, pull the head it will take all of an hour.
The killer is not the engine as you can get a running one for a few hundred dollars. The bulkhead and chassis are the issue. If they are ok, it is restorable. If not, they are expensive, but it is still restorable.
Pictures please.
MarkIIa
Just imagine, your '63 88" IIa could look like this '63 IIa, or even better!
See that smile? That could be your smile, your pride!
Now go make it a reality!
steelheadbum
NOT WORTH SAVING!! Send me your address I'll come tow it away for ya!!:D
Buck
The Redneck Mexican
2002 E350 7.3 PSD 4x4 8inch lift pop top conversion....
dhuss
