zonker
I am getting ready to head out to the Mojave and of course that means there will be sand. I am curious as to what kind of low pressure I can use with my Dodge 2500 and easily keep the bead seated? Here is the scoop on my setup. It is an '06 with a Cummins and FWC Hawk I have upgraded tires to one size larger.. 285/70/17s in a Goodyear Duratrac in a load range D.. which will handle 3195 lbs per tire at max pressure. Generally I have 52 lbs of pressure in each tire for general use. Also I have the standard Ram LSD in back.. nothing in the front. Stock suspension that is mildly compressed due to the completely loaded weight just shy of 9,000 lbs which is very well distributed and close to 50/50 front to rear.
So any thoughts on what my lower limit on pressure would be? Also what would be a good all around pressure for general off-road? This is a new setup for us.. and especially sand.. so I would like to cheat on the pressure as much as I can and avoid taking out the Maxtrax too often!
