Wheel/hub question on trailer build
clark98ut
My parents had a trailer laying around that they weren’t using, so I figured I needed another project.
I ordered a new Dexter axle for it with 5x5 hubs in a custom width with the intent of running a set of take off Jeep Willys wheels on it. Today I got the new axle mounted up and ran into a problem installing the wheels.
The Jeep wheels are hub centric. The Jeep wheel will not clear the hub on the trailer axle. My question is, would there be any harm in grinding down the wheel to clear the hub?
Thanks,
Dan
quickfarms
You need to use a spacer for this.
Grinding the hub is not an option.
Having them machined may be, but you could significantly weaken the hub.
Psyph
