I'm new here and new to solar for camping(or solar anything), looking to build a system for my camper/trailer. I came across this write up/review of a panel sold on Amazon:
I ordered this to evaluate its possible use in developing a 1kw electrical source for use in RVs and motor homes. My panel was evaluated by using it to charge a 12 volt 100amp hour battery. During the charging the panel delivered 12 volts at 4 amps or 48 watts. During the charging the panel was equipped with an auto tracking mechanism to ensure maximum energy production. The output of the panel remained constant at 12 volts and 4 amps. It did not seem to be effected by temperature. This is NOT a 100 WATT solar panel. This is a 48 WATT solar panel. Renogy multiplied a 20 volt open circuit voltage by a 5 amp short circuit current and declared the panel a 100 watt panel. That is not the way to determine wattage capability and causes me to seriously doubt Renogy technical expertise
How often is this the case? Not being solar literate I thought 100 watt panel is a 100watt panel but apparently the marketing departments, as with most all products, have their say in how the specs are measured for public consumption. This happens to be a Renogy(not picking on Renogy) but most likely others do the same. How can I tell what I'm getting before I buy, comments and info appreciated.
thanks, Brian
thanks, Brian
