When to replace O2 sensor
rajin cajun
I recently completed severe service preventive maintenance on my Monty.
Should the O2 sensor be changed in preventive maint? My MPG have decreased, but i put larger tires on.
Of course, the owners manual states every 100,000 miles.
Thanks in advance..........
bpfamily
rove around
On my 1990 SWB the O2 sensor was throwing a code so I replaced it. It had no effect on the drive-ability of the rig.
Best,
Brad P.
off-roader
May be a good idea to replace if the threads aren't seized yet. This way you can ensure you use the appropriate anti-seize compound during the re-assembly process. At a minimum, I'd remove the old sensor and re-apply new anti-seize to it's threads then re-install it.
Goldenbora
