08cummins2500
Looking to install an ARB CKMTA12 dual compressor on my 08 Dodge Ram 2500 along with an air tank, lines for tools and inflation gear, and provision to add air locker(s) later. I would like to keep my truck mostly stock looking and functional, meaning I'd rather not have bits hanging off everywhere, risk the compressor being damaged in the bed of the truck, or add a toolbox which would permanently take up the already limited space in my 6'4" short bed. I'd also rather not have it in the cab, as all the little cubbies are already full of all the junk I've convinced myself I need. Worse still, there isn't much room under the hood with the 6.7 Cummins stuffed in there, so I'm trying to get creative.
I have two ides, and I would appreciate opinions:
1: Under the cab mounted to the passenger side frame rail between the frame and the rocker panels/door bottoms. I've seen people mount compressors for air bags and horns here, but I'm concerned about what it could do to the longevity of my pricy new compressor. I already have AMP Research Power Steps installed, which would provide some cover from sand/mud/dirt/spray, and I could build the bracket in a way to help shield the compressor and install remote air inlets to pull in clean, dry air. The plus is easy access for mounting and servicing. The minus is the potential for ruining the compressor from exposure to the aforementioned environmental hazards. The Power Steps already keep me from thinking about crossing deep water and submerging the mount point since their motors are also mounted in the same area.
2: Just forward of the rear wheel between the sheet metal of the truck bed and the exterior body panel. I've noticed there's sufficient room here (maybe hard to imagine), and this would allow me to mount it much higher up and away from any potential water submersion, and the full wheel well liner should help protect from sand/mud/dirt/spray. The minus here is the difficulty in mounting and servicing.
I should also add that while I hope to explore some remote regions I won't be deliberately entering deep water or mud holes, doing any rock crawling, or otherwise tackling any really technical terrain. I do want to explore beaches, moderate desert tracks, and forest service roads, so in addition to regular highway hazards it should be at least moderately protected wherever it goes.
So, where have you mounted a compressor in a full size domestic truck, what has your experience been with wear and tear/longevity, and am I crazy for thinking of these mounts?
Thanks!
Thanks!
