Where to buy *really* long gas struts?
Dan Grec
HI everyone,
I'm designing a custom pop-top, and I want to use gas struts kind of like the following:
I want the struts to be really long so I have tons of angle on them when the roof is "up"
So far I've only found struts to a max of 44" when fully extended.
Does anyone know where I can buy struts that are 50" or even 60" long?
Thanks,
-Dan
NatersXJ6
Be sure to do research, research, research and then more research when calculating gas strut length, force, angle. I decided to change the weight of my AT Chaser lid, which required different gas struts mounted in different places. It cost a fortune as I went through 3 different cycles of trying and still ended up with not quite right!
robtbritn
McMaster is another great source, tell them what you want and they can usually find it...
zhukoveli
